(DE) eBackUp ist ein Datensicherungs- und Wiederherstellungsprogramm für OS/2 und eCS, das für die Datenspeicherung "Rar32 für DOS/OS2" verwendet. Es wurde mit WDSibyl erstellt.
Deutsche Homepage
Download der neuesten Version
(EN) eBackUp is a backup and restore utility, using "Rar32 for DOS/OS2" to compress and archive and to extract files and directories. It was built using WDSibyl.
English Homepage
Download latest version
eBackUp
- ARoederer
(DE) Hanno hat die Version 1.04 am 18.04.2012 von eBackUp mit einigen Neuerungen und Erweiterungen freigegeben.
(EN) Hanno released the new version 1.04 of eBackup at 18.04.2014 with some new funktions and fixes.
Changelog 1.04 (18.04.2014)
Download eBackup 1.04 (18.04.2014)
- "-log" added as possible startup parameter (for debugging purposes)
- SelRestUnit: changes for help on F1
- uRegLimited: 'Free' instead of 'Destroy' for mTimer
- various small layout and text changes
- PipeUnit: "No such file or ..." added to FilesAnzError warnings
- MainUnit: the created CMD-scripts now include the path to eBackUp-exe
(no need to keep CMDs within eBackUp folder or set "Working directory)
- ARoederer
(DE) Hanno hat die Version 1.10 von eBackUp am 27.06.2012 mit einigen Neuerungen und Erweiterungen freigegeben.
(EN) Hanno released the new version 1.10 of eBackup at 27.06.2014 with some new funktions and fixes.
Changelog 1.10 (27.06.2014)
Download eBackup 1.10 (27.06.2014)
- Restore-tab: added possibility to change the physical path of an archive
- Deletion of archives and catalog-entries completely rewritten (now possibility to delete multiple archives at once)
- (System)OpenDialogs: text for Caption/OKName/Title adjusted
- ProgressBar_Status: separate bar colours for: ok/warnings/errors/fatal error
- Logic of F1-Help moved from commands(units) directly to the objects and therefore fixed "general help-content" as target for icon-help
- Loading of Cats improved (only done if neccessary [tab-change etc.])
- eBackUp_DE.LNG: translation for field Label_RegTxt removed to avoid wrong license-info
- various layout changes
- BeginUpdate/EndUpdate for all MultiColumnLists while loading
- Actions.log: DateTime changed to starting instead of stopping time
(used now as ID; needed for synchronity with archive name and catalog entry)
[known problem: lines in action.log have to be deleted manually for versions before 1.10] - SetUnit: correct handling of intial values for drive and directory on "Add drives/directories"
- Misc-tab: reset displays and catalog selection when an archive is manually added
- SetUnit: automatically DeleteLastPathSeparator for "exclude" directories (see help)
- Help: corrected some issues with links and references
