Zippy: To extract modern archive formats
Eugene Gorbunoff
Beitrag von Eugene Gorbunoff »
If you "compressed" many clothes to travel bag, then it's difficult to pick up needed item:
Zippy allows view the archive contents, select and extract needed files and directories immediately.
Zippy homepage: http://ecomstation.ru/zippy
Zippy 0.07.00 whatsnew:
* Added full support of drag and drop. You can drag and drop archived files or directories to any WPS folder or trash can. You can also drag and drop any WPS folder or file to Zippy window to update or create new archive.
* Added new check box to the extraction dialog that allows to show the destination folder after extracting.
* Now if you mark archive item holding down SHIFT key, you can mark a group of items. Also you can mark or unmark all items of the current container view using CTRL+/ keys.
* Added option that allow reuse one password in all archive operations. This is simplifies usage of encrypted archives.
* Now, if you add a files with partial paths to opened archive, they are added to current selected directory.
* The newly created archive is now loaded into the browser after the finish of file compression.
* Optimized memory usage.
