Apache OpenOffice for eCS (OS/2) 4.1.1.1 GA
Post by _diver » Tue 17. Feb 2015, 13:09
St. Veit an der Glan, Austria, February 10, 2015 — 1 month after our
Apache OpenOffice 4.1.1 GA, we are now proud to present the 2nd GA
version of 4.1.1.
This GA is rebuilt with our latest compiler. With this compiler we
were able to reduce the memory footprint significantly. This should
bring more stability on some systems.
The GA version includes english, german, italian, french, spanish,
dutch and russian language pack. And of course this version comes
nicely packed in a wpi.
Apache OpenOffice is the free and open productivity suite, consisting
of several mighty applications, such as Calc, Writer, Base, Impress
and several more. Apache OpenOffice is compatible to the leading
commercial productivity suite.
Download Apache OpenOffice 4.1.1.1 GA from:
https://www.dropbox.com/sh/hd9a9sjr8jsz ... bfRia?dl=0
The password to download the file is: bww
You need only one complete wpi for your preferred language.
If you want to install an additional language you need only the
language wpi for the new language.
For additional installation information, please read the
readme_aoo.txt file. The file can also be found in the
directory from the download link.
To fill a bug please use:https://issues.apache.org/ooo/
If you create a ticket, please also set your ticket to block ticket 118923.
If you like Apache OpenOffice, please pass by our online shop at
http://www.bitwiseworks.com/shop and donate for Apache OpenOffice for
eCS(OS/2). These donations support the ongoing development and
bugfixing efforts.
With regards, the bww bitwise works GmbH Team
Post by ak120 » Thu 19. Feb 2015, 12:17
Gibt es irgendwo eine Liste mit den Änderungen? Braucht man jetzt die Innotek FT2 Bibliotheken nicht mehr, da ein anderes FT2 genutzt wird?
