Aveo Technology Corp. UVC camera (Bresser microscope)
dieses Schätzchen würde ich gern unter ecs 2.1 und/oder ecs 2.2 nutzen.
Der Device-Report sieht so aus:
<<< Device Description >>>
 Type            : 01
 USB Rev         : 200
 Class           : Unknown class EF
 Subclass        : Unknown Subclass EF
 Protocol        : Unknown Protocol EF
 Max. packetsize : 40
 Vendor  ID      : 1871
 Product ID      : 0101
 Device Release# : 000C
 Strings:
  Manufacturer Name : AVEO Technology Corp.
  Product Name      : USB2.0 Camera
  Serial number     : Not implemented
 Number of Configurations : 1
 Configuration 0 :
  Lenght     : 419
  Value      : 1
  Attributes : 0x80
  Power      : 500 mA
  Interfaces : 2
No Interface 0x04, Endpoint 0x05 or Classspec 0x21-0x025 Description is 0x0B
  Interface 0
   Alt Setting : 0
   Class       : Unknown class 0E
   SubClass    : Unknown Subclass 0E
   Protocol    : Unknown Protocol 0E
   Endpoints   : 1
Class-Specific Interface Descriptor, Size : 13
Class-Specific Interface Descriptor, Size : 18
Class-Specific Interface Descriptor, Size : 9
Class-Specific Interface Descriptor, Size : 11
Class-Specific Interface Descriptor, Size : 26
   Endpoint 0:
    Address     : 85
    Attributes  : 03
    Packetsize  : 0040
    Interval    : 7
Class-Specific Endpoint Descriptor, Size : 5
  Interface 1
   Alt Setting : 0
   Endpoints   : 0
Class-Specific Interface Descriptor, Size : 14
Class-Specific Interface Descriptor, Size : 27
Class-Specific Interface Descriptor, Size : 30
Class-Specific Interface Descriptor, Size : 6
  Interface 1
   Alt Setting : 1
   Endpoints   : 1
   Endpoint 0:
    Address     : 83
    Attributes  : 05
    Packetsize  : 020C
    Interval    : 1
  Interface 1
   Alt Setting : 2
   Endpoints   : 1
   Endpoint 0:
    Address     : 83
    Attributes  : 05
    Packetsize  : 030C
    Interval    : 1
  Interface 1
   Alt Setting : 3
   Endpoints   : 1
   Endpoint 0:
    Address     : 83
    Attributes  : 05
    Packetsize  : 03FC
    Interval    : 1
  Interface 1
   Alt Setting : 4
   Endpoints   : 1
   Endpoint 0:
    Address     : 83
    Attributes  : 05
    Packetsize  : 0BFC
    Interval    : 1
  Interface 1
   Alt Setting : 5
   Endpoints   : 1
   Endpoint 0:
    Address     : 83
    Attributes  : 05
    Packetsize  : 13FC
    Interval    : 1
Ich glaube alle Requirements erfüllt und alle Installationsschritte durchgeführt zu haben, dennoch passiert folgendes:
Liegt es wiedermal an mir?
Hiermit habe ich ebenfalls experimentiert, bisher ohne Erfolg.
rem DEVICE=D:\OS2\BOOT\USBECD.SYS /D:1871:0101:000C /N:SNX$
Schade :(
Wimpie
Beitrag von Wimpie »
It does not look too bad. It appears that you are using the 320x240 format at the highest possible bandwidth. This might be a combination that this camera does not like. There is a parameter that allows you to choose a lesser bandwidth setting. So please experiment a little. This parameter applies to uvcview.exe and weblook.exe only. By default these programs use the highest bandwidth (i.e. the same as /i5) available to your camera.
uvcview /i5 uses 3 x 1020 bytes
uvcview /i4 uses 2 x 1020 bytes
uvcview /i3 uses 1020 bytes
uvcview /i2 uses 780 bytes
uvcview /i1 uses 524 bytes.
Wim.
Hi Wim,
here are some results.
When booting with camera plugged in, calling uvcview offers a black window and a trap 000d in USBEHCD 000F:E667 after closing the window.
When starting uvcview without parameters and without plugged in camera there comes a message 'UVC Webcam not found' then plugged in camera and pushing 'retry' the window shows pictures for a while (about 30 seconds) then [00000280] Obtain Thread error!
With /i5 the time before [00000280] Obtain Thread error! expands into minutes.
Taking a snapshot with 320x240 is possible, but then [00000280] Obtain Thread error! comes up immediately.
Taking a snapshot with 640x480 works sometimes.
I am testing with IBM-Kernel from ecs 2.2 and OS/4 Kernel.
OS/4 Kernel sometimes does not boot with plugged in camera.
That helps a lot. Much better than yesterday. :D
Wimpie
Hi Wilfried,
o.k. :) nice. Some video already.
It is possible that you need a better combination of usb drivers. So please tell me which drivers you are using. Are you using the Arca Noae 11.13 drivers already? Probably not. Run bldlevel against usbd.sys and usbehcd.sys and usbcalls.dll and usbresmg.sys that you are actually using.
Right. The usbecd.sys driver is NOT used at all with the Webcam Support provided by WebSee10.zip which uses the usbcalls/usbresmg combination.
USBD.SYS 10.197 Lars Erdmann
USBEHCD.SYS 10.197
USBCALLS.DLL 14.20150118 W. M. Brul
USBRESMG.SYS 14.20150303 W.M. Brul
These are from the packages you mentioned on your homepage for using websee.
Wimpie
Yes, right you are. I must say that I don't know what to do next. I could send my latest version of usbcalls.dll and usbresmg.sys for you to try out. I'll send it to your private email address that I have. I rather not post it here because the proper documentation is not finished yet. So you'll have to keep it to yourself.
Wim
Hi Wim,
thanks for your special support!
Starting uvcview without parameters offers the best result.
The camera shows more than 5 minutes video without freezing and without errormessage.
After maximizing the window or taking a picture the window freezes and the known errormessage is shown.
Picture saving works only with the OS/4 kernel.
After a freeze the camera needs a reset, unplug and plug in does the trick, but is it possible to give the camera a software reset when uvcview is starting?
When you tell me what to do, I will try to gather debuginformations for you. I am new with this topic but my first attempt to catch the kernel boot messages of the OS/4 kernel worked fine.
I think I need a debugkernel for this and the symfiles but do not know further on.
Wimpie
wilfried hat geschrieben:Hi Wim,
Is it true that you got better results with the update that I sent you yesterday? In that case I have another update that I can send you later today. I'll have to build it first though. If that improves it even more then I could try and modify uvcview to use smaller buffers.
I was not able to implement a software reset. You might try to start uvcview twice i.e. when the timeout error 280 occurs start uvcview again and when you get an error try to start uvcview once more.
That I cannot do. I am not familiar with kernal debugging. May be you are using an smp system with more than 1 core. I don't have that. I don't use the OS/4 kernal either. May be it works better if you run with one core enabled only. I don't really know what I am saying here. Feel like a parrot. If the problem has to do with smp then I cannot recreate that, let alone solve it.
Wim
Yes!
[Testszenario:]
IBM Kernel 2.2 on T60 SMP 2 CPUs, plugged in camera on boot, uvcview without parameters
- Boot
- uvcview, freeze after seconds [000280]
- uvcview, black window
- uvcview, video for minutes, freeze and [000280] after trying snapshot, picture was not taken
- [message typing pause, about 30 seconds]
- uvcview, video for minutes, freeze after moving mousepointer over the window
[/Testszenario]
When camera is working cpu 1 is using about 20%, cpu 2 is idle.
When mousepointer moves over the camera window cpu 2 comes to work and camera freezes
When mousepointer moves around anywhere on the desktop cpu 2 comes to work and camera freezes
Hypothesis: When the camerathread has to switch the cpu, then the problem arise.
HTH
Two things are important for me:
- can you change uvcview so that the maximze window size is already shown at startup (640x480)
- when storeing snapshot comes to work with or without freeze then the camera becomes useful for me (see edit2:)
edit:
Starting a cpu consuming process (IrxRadio), both cpus are used.
When uvcview is starting afterwards, only cpu 1 is used further on but both programms work fine. The mousemovement brings cpu 2 to work and that make the camera freeze.
edit2:
I think the snapshot function can be obtained with PMVIEW, seems not so important in uvcview
edit3:
Only \320x240\uvcview.exe without parameters does not freeze. \640x480\uvcview without parameters or with /i5 freezes after seconds everytime. \640x480\uvcview /i1 - /i4 only show a black window.
Zuletzt geändert von wilfried am Mi 8. Jul 2015, 16:15, insgesamt 2-mal geändert.
How can this be done?
Shoud I remove PSD=ACPI.PSD from CONFIG.SYS ?
Wimpie
I have created uvcscope.exe which uses more isochronous buffers. And it starts up maximized.
http://home.hccnet.nl/w.m.brul/uvcvideo/uvcscope.zip
wilfried » Mi 8. Jul 2015, 15:53 hat geschrieben:
Ergänze:
PSD=ACPI.PSD /MAXCPU=1
UVCSCOPE:
640x480 on startup works fine.
With both cpus active, the freeze problem persists.
With /MAXCPU=1 (Thanks Sigurd) we've got it. No freeze anymore. Snapshot works fine also, nothing to do for PMVIEW PRO. ;)
Thanks Wim, you made another USB-toy working for me!!!
If you need more testing, you can count on me.
Wimpie
wilfried » Wed 8. Jul 2015, 16:51 hat geschrieben:UVCSCOPE:
Nice. :D Just one more test. The attached version might work even better. Please try.
UVCSCOPE.ZIP
UVC Microscope
(9.05 KiB) 358-mal heruntergeladen
In fact the real problem of working with more than one cpu has not been solved.
Wim.
It works fine with 1 cpu, with 2 cpus collecting freezes only, no difference.
What did I miss?
Wimpie
wilfried » Wed 8. Jul 2015, 17:47 hat geschrieben:It works fine with 1 cpu, with 2 cpus collecting freezes only, no difference.
What did I miss?
You missed nothing. I made a slight change in the order of taking a snapshot and refreshing the window which appeared to have no effect. Thanks for testing it out. I am done with it now.
Best regards,
Wim
Ach und ganz nebenbei funktioniert "natürlich" auch meine Webcam. :D
Die Farben werden etwas grau dargestellt, zB. bei den Haaren.
Das ist nicht grau, das ist altersblond. :roll:
Hier noch ein Codeschnipsel für das 'Image post processing'. Soll verhindern das der letzte Snapshot überschrieben wird.
d = date('S')
t = time('S')
f = 'uvc'd'_'t'.jpg'
'COPY uvcscope.jpg' f
return
Wimpie
Hi Wilfried,
To show success I would appreciate to see a snapshot of a specimen under the Bresser microscope being posted here.
Wim.
Hi Wim,
here we go:
20x
20x
80x
80x
350x
350x
As you can see I am a coin collector.
I use the scope to checkout success of coin cleaning.
This is a candidate, not yet cleaned.
And here the full picture with my webcam
1x
1x
By the way, what about the situation if I want to use more than one camera at the same time (NSA)? ;)
Is there a feature thinkable to address the camera or a window with all camera streams shown up?
Wimpie
Thank you Wilfried. :o I appreciate the sample chosen. I am impressed by the result. Keeps me motivated!
How it works right now. Both programs weblook and uvcview scan for a webcam. When one is found an attempt is made to acquire that webcam. When a webcam is already acquired the program ends. Therefore the only way at this moment to acquire the other webcam is to have that one not yet plugged in when you start the first program. After starting the first program plug in the second webcam and start the second program. But I am afraid that the first webcam will freeze when you plug in the second webcam.
One way would be to invent a parameter to these programs that provides the idVendor and idProduct to be used to acquire the webcam instead of searching for some webcam. I don't understand "window with all camera streams shown up" Do you mean a window listing available webcams that can be chosen from? Do you mean a window that shows the video from several cameras at the same time?
Wim.
This version please.
In one combination of used USB Ports, I can plug in the second camera without freezing the first one. Starting the second program offers a
[0000FF15] leaving the first camera alive.
Wimpie
wilfried » Fri 10. Jul 2015, 12:50 hat geschrieben:
That would be too much work. I am not going to do that. Sorry.
The [0000FF15] means not enough bandwidth available.
Wim
