Bitwise Works Newsletter - 10. September 2014
Post by Frank Wochatz » Thu 11. Sep 2014, 09:24
bww bitwise works GmbH progress update September 10, 2014
We are finally done with the long awaited git 2.0 software port. Unfortunately this port took us very long, as we had to do a lot updates on other ports, as well as some new ports. Git and all the needed requirements can be installed with "yum install git". If one doesn't like yum there is the possibility to download the zip package of git and install it from there.
If you are curious in what was added or changed for the git port, please have a look at Unix Ports
We are now switching to Firefox again and we hope to have a fresh beta out very soon.
If you are interested to see the progress on Firefox, please have a look at Firefox for eCS (OS/2)
Sponsoring:
If you want to support us or a specific project then please check out these links:
www.bitwiseworks.com/shop
You are one of the people making the future possible!
With regards, the bww bitwise works GmbH Team
