Uno Fixpak 3 for eComStation 2.x
Eugene Gorbunoff
Post by Eugene Gorbunoff »
The Fixpack contains fixes and useful utilities for eComStation operating system.
Installation:
* Download ecs2-uno-fixpak3-xxxxxxxx.wpi package
* Start installation of .wpi package
* During installation select: Overwrite all, Unlock All
System requirements:
* eComStation 2.0, 2.1, 2.2
* Disk space: 10 Mb
Feedback from users:
* It's not easy to select what modules to include to the fixpak.
There is no need to install all files from hobbes. On the other side,
the fixpak should contain important apps and utils.
* We are collecting all suggestions what fixes/utils to include to the Fixpak.
(Send ideas via web-form: http://ecomstation.ru/support.php)
Homepage:
http://ecomstation.ru/fixpak
Post by Frank Wochatz »
What exactly has been included in this fixpack? Is there any documentation?
Post by LotharS »
Nicht dass ich jetzt werben wollte, sondern nur als Info: ganz unten im Posting stand der "Homepage"-Link. ;)
Auf "Englisch" wechseln und "Components" klicken...
Das muß man aber auch erstmal finden. Danke Lothar. :)
Direktlink zu den Kompontenten
